Fleetwood Heritage 600 CB 2002 – No Interior Lights (All Other Systems Working)
Oct 2, 2025
11
The question is whether they could potentially be the issue preventing all the lights from working. I could, for example, swap them to see if that helps, but I am not sure if this would make any difference.
Apr 23, 2024
458
379
935
The relays look in good condition, the contacts aren't damaged and there no evidence of arcing ( metallic black/grey deposit on plastic case) also the coils have no discolouration which would indicate overheating ( which would cause the wire in the coil to break).The bottom relay is probably the isolate relay ( cuts off the 12V system when the car is plugged in).So if the rest of the 12V systems are working( orange wires have +12V on them) then that relay contacts are OK.
Tracing out the green (with brown markers) wires is the next thing to check, do they have +12V on the them . A convenient 0V in the fuse box is the black wire on the bottom relay.
Reactions: gizickim
Oct 2, 2025
11
Thank you. I will check it out later today. I have a wire extension for my multimeter, so I will make sure to check whether it is the ground or the V+ that is discontinuous.
5,301
You will see on another post I had trouble with my interior 12v lights .
Testing the circuit section by section ,it was the 12 v master switch that had failed. A replacement fixed it.
Oct 2, 2025
11
Another update after a full afternoon of testing.
When I connect my multimeter’s negative probe to a separate known good earth (chassis or battery negative), I’m getting +12 V on both terminals of the bulb connector. That means the positive feed is fine, but the negative/earth return isn’t actually connected — it’s floating at the same potential as the live side.
So the fault definitely appears to be on the earth side of the lighting circuit rather than the power feed.
Sep 23, 2023
1,348
584
2,435
What make if known is the unit,on my system the negative cables are collectively fitted into a 12 way plug that is inturn is connected to a 12 way socket fixed on the unit,if this was to become loose on mine for whatever reason I would lose all V- ,perhaps if only partially loose it may only be certain circuit(s) that were lost
