Flickering Lights?
Noticed this last week? Seemed to stop after a while and only flickered on the side lamps which are 240V only? Going back to the same site same pitch this weekend so will see if it does it again?
Could it be the mains hookup or something wrong with my own van (2004 Van)?
If in doubt have your caravan checked by a competent electrician. Then if there is a fault on the site at least you should have some protection through your own safety equiepment in the caravan.
Flikering lights on a caravan site is quite likely to be due to local power loading on the sites supply, all those caravanners turning on thier tellys and kettles etc.
We get this on most sites we go to, the flickering only happens when we use the dimmer spot lights on low dim and when the lights are on high the flickering stops, been told nothing to worry about.
