Folding bucket
In either CC mag or C& CC mag recently there was an advert for a folding bucket. I seem to have thrown this away so does anybody still have a contact website please?
Thank you Parksy. I did try that and all I have found as yet is the collapsible ones. The ones in the mag. were a bit more like a concertina type and looked as though they would be more robust which is what I am after. Are you enjoying the sunshine!?
Hi Chrissylizzie
I hope that the sunshine will still be around later this month because we're hoping to attend the first DA rally of the year which is a five day meet starting on 17th
Hi Chrissylizzie
fingers cross Parksy. Which DA do you belong to?
We have the one that Parksy came up with.
Unless its simply to transport water don't bother as if left standing on its base as in "fire bucket" it ultimately in time topples over.
It can be hung off the hitch etc, then its okay, but the handle is a bit tight for the hitch though possible.
West Midlands, it's their AGM next week at Yew Tree Farm, Bewdley.
We only started rallying last year and we enjoy it, we sometimes rally with Birmingham DA who are a nice friendly crowd as well.
Thanks for the info. JTQ - I will bear that in mind.
As per:
If you have you ever had problems trying to find somewhere to store your bucket, the solution can now be found with the new Pack-Away, fully collapsible, rigid bucket - with a generous capacity of 7 litres, the Pack-Away bucket flat packs from a total height of over 35cm, including the handle, to a height of less than 5cm.
Easy to extend and easy to collapse, the silicone bucket will not scratch or dent surfaces. The silicone material also helps to ensure that the bucket does not slip as easily as plastic designs.
The Pack-Away bucket is available in green, navy, black and red.
The Pack-Away bucket is ideal for gardening, DIY, sailing, camping and caravanning and equestrian shows.
Folding Bucket
I thought it was something new that every one was one about. We had one of those about 20 years ago and found it to be quite good.
Unfortunately after a few years use the concentina bit started to split and even Elisah could not fix the hole in the bucket!
