Simple question, Can a large van be manoeuvered using two motors instead of four or is it a case of a trade-off between extra weight and manoeuverability? Which one would you go far.
Why should going to the continent make any difference? What is your reasoning?If visiting the continent then 4 WD motor is essential. We initially had the 2 for about a 18 months and then upgraded to the 4WD. It does make turning a lot easier, but there is a weight penalty.
A lot of “Continental “ sites are very cramped, tight spaces. The more manoeuvrability the better. But my single axle motors on the ta do the job. Just takes a lot longer 🤪🤪Why should going to the continent make any difference? What is your reasoning?
My Powertouch will complete a 90° turn, but it needs the full width of our street to do it.Single axle caravans can usually rotate on the spot by driving the wheels in opposite directions , but I am not aware of an twin axle mover that can do the same: the tyre scrub resistances a simply to great for the mover to over come.
I recall there used to be one TA mover that basically shuffled the caravan round, but even that needed to mover forwards and backwards several times to complete a 90 degree turn.
I'm sure there will be a mixture of easy and difficult sites both here and on the continent.
My 12 year old Powrtouch isn’t wired that way. I know the later ones will allow opposite rotation to assist in turning. I may ask Powrtouch if mine can be modified.When turning you can use the right forward turning button and the rear left reverse turning button. Thye are diagonally opposite one another. Stabbing motion helps to turn it quite quickly. A lot less scrubbing of tyres however if on gravel or similar scrubbing is not a big issue.
Are you saying it turns about the centre of the axles with forward and back (shuffling) movements to accommodate it?My Powertouch will complete a 90° turn, but it needs the full width of our street to do it.
No Prof, the controller on my motor mover has forward , forward left and forward right buttons and the same for reverse.Are you saying it turns about the centre of the axles with forward and back (shuffling) movements to accommodate it?
That’s what my old Powrtouch misses
