Fuse blowing regularly on conqueror caravan
Aug 5, 2024
Conqueror swift caravan just out of warranty fuse keeps blowing, which operates the spot lights, cooker ignition and toilet flush. Any suggestions?
2,706
If any fuse keeps blowing there has to be a fault in the circuit that it feeds. Unusual for a led, but bulbs can fail and cause a short. First try isolating the spot lights and seeing if the fuse still blows. In this way, you may find a culprit.
5,334
How old is the caravan? If bought new, then warranty may still apply? As said very unusual for LEDs to blow a fuse. I don't think that the lights or cooker ignition draw a high current? It is possible that the toilet flush i.e. the pump is the culprit and if so that is would still be under warranty on a new caravan.
