gas bottle fitting
Aug 25, 2006
75
we ran out of gas this weekend and had to get a change.
the one thing i noticed was the hose that attached to the bottle didnt have a seal or o ring,it is for the red gas.
should it have one or not,i leak sprayed the fitting and all was good,no leak.
the van is only a month old so wasnt sure if it was left off
Jul 15, 2005
2,175
Hi,
When you say red gas, I assume you mean Propane supplied by Calor Gas - different companies use different bottle colours for the different gases.
Propane pig tail hoses normally have a hemi-spherical bull-hose end that butts into a matching socket on the bottle head, and these are gas tight at the medium gas pressure found in a Propane bottle.
The disadvantage is that you need a spanner to apply sufficient force to make the seal, if this is an issue - you can change the pigtail for one with a rubber bull-nose - and this will seal with a simple hand-twist.
Butane gas (lower bottle pressure) usually employs a flat-to-flat butt joint and this uses a flat rubber washer.
The leak check was a good idea - always do this when changing
bottles - a drop of liquid detergent in water works very well.
And the above ignores the "snap-on" type bottle connectors - best not to go there.
Robert
Aug 25, 2006
75
hi rob
yeah it was the calor gas bottle,i used the right spanner
to make sure it was ok.
thanks for that ,good to know i wasnt missing anything
