Gas bottle valves
Hello
As the old saying goes 'if you don't know, ask', so here goes...
I've got a leisure/propane gas bottle that I used for my old gas bbq and a Cadac Safari Chef bbq we use for the caravan. The clip on valve that I bought with the Cadac is 22mm, but I'm wondering if it's possible to buy an adapter that allows you to couple it up to the 27mm valve on the leisure gas bottle in a similar way that you'd a reducer on pipework 🤔
Col
Can you not remove the 22mm clip on valve and fit a 27MM clip on?
Here is an example where the interface hose to clip-on is a LH threaded one that is typically used.
LINK
Whilst not unknow 22mm clip-on is way less commonly used than 21mm or 20 mm clip-ons. Though these very frequently use the LH thread as the interface.
If you have Propane it will be threaded. If you want to use a clip on you will need to change Bottle to Patio gas or Butane.
I use quick release connectors on my Cadac. So with a couple of connectors where each one is attached to a length of hose with a regulator, connector suited for a specific gas cylinder. So I can easily connect to a Campinggaz, or patio gas cylinder using one or other of the connectors. You could do similar with a 27 mm cylinder too.
"If you have Propane it will be threaded"
Being Propane does not in itself dictate it "will be threaded", for example if he has Flo-gas (exBP] Gaslights it will be Propane and will be a 27mm clip-on.
This is why I stated Patio gas, as alternative Bottle.but standard Calor Propane are threaded
