https://www.truma.com/web/downloadc...ion-operating-de-en-fr-it-nl-dk-se.pdf[/quoteGrey13 said:This valve is an automatic change-over valve. I use it then simply fill the empty when necessary.
https://www.truma.com/uk/en/products/truma-caravan-rv-gas-fittings/truma-duocontrol.html
]https://www.truma.com/web/downloadcenter/files/truma-gas-supply-duocontrol-installation-operating-de-en-fr-it-nl-dk-se.pdf
ProfJohnL said:Truma used to do a version with a remote indicator, But i don;t see it in their listings now.
All it needs is to check them once or twice during a holiday, find one empty and change it.
Boff said:...With regards to gas level in cylinder. Because we use a lot of gas you can actually feels the temperature change, or in colder weather see ice on the outside of the bottle that stops at the top of gas level.
EH52ARH said:I still have two calor lite bottles, the dealer says the problem is getting the old heavy ones. Just about to fill the empty Lite one. Just a shake and I know to carry the second full bottle. The almost empty one runs on forever, until half way through cooking. Bah Humbug.
Gra1 said:I think I've seen a pressure gauge with red /green type indicator sclae that you can put before the regulator. Anybody have knowledge or comments on these?
I bought one off ebay, its a little dial you put on the end of the gas connector. Works fine for me, and much better than the magnetic ones! The best bit it was only a fiver!
