- Mar 14, 2005
- 19,227
- 4,396
- 50,935
Gafferbill said:.........................I personally do not think the gas product is the problem.
What is the basis of your belief? Can you offer another credible explanation for the oil deposition?
Gafferbill said:I personally do not think the gas product is the problem.
JTQ said:Gafferbill said:I personally do not think the gas product is the problem.
I share that view, "the problem" is that these regulators can't live with the residue; as has been said the residue itself is not a new issue, its the regulator jamming from it that is the current problem.
That in no way supports the acceptance of dirty gas or leaching of plasticisers some blame on the regulators jamming; things should be clean, but it is these regulators, unlike those before, not tolerating the actual environment they are sold to work in, that is the problem. Arguably they are not "fit for purpose", ie., use within our caravanning/motorhoming gas systems.
ProfJohnL said:Gafferbill said:.........................I personally do not think the gas product is the problem.
Damian-Moderator said:
Gafferbill wrote........" I personally do not think the gas product is the problem. "
As Prof.John l has asked,,,,,,if you do not think it is the gas, what do you think it is.
I would be very interested in your reply.
The things to consider are:
1. A cylinder of gas.
2. A means of connecting the gas to the van ,
3.The gas in the cylinder just sits there until it is used.
4 The connection to the van and the van pipework just sit there until gas is passed into the system.
5. Once the two components are brought together,then the residue problem arises.
6. The residue has always been present,even in the older systems which did not use 30mB bulkhead regulators, you probably did not keep a van long enough for the problem of blocked pipes to manifest itself.
Sproket said:
Rodone said:Hello Prof,
I know little about gas regulators, but for many years I have used Gaslow auto changeover valve/ regulator more latterly with the stainless steel pigtails. The regulator is fitted high on the bulkhead, as it was on my last 3 vans, and I have used Calorgas and Flowgas.i have never had any sort of problems with the Gaslow set up and wonder if that kit differs in some way from Truma?
