Golf 130 Diesel towcar?
Jul 4, 2007
16
Hi I am thinking of getting a mk4 Golf 130tdi estate with 6 speed box, as its max to wieght 1400 is 100kg more than my vectra 51 plated 20l Dti. does anybody use one for towing good or bad? I thought it had a good strong engine. but not to big a car. cheers
Apr 17, 2005
117
Hi Jago,
I have towed with a Golf TDI130 estate for five years now, with no problems. Sixth gear (2000rpm at 70mph) is not often sensible, but fifth is ideal for me most of the time.
I would say a service record is very important when buying, and try to persuade the seller to replace the cambelt etc., unless this has recently been done. This is a costly service if performed by a VW main agent.
Towing I average around 32mpg, but obviously this varies according to conditions; solo I usually get around 54 mpg measuring between fill ups, but this can vary between 50mpg and 60mpg on individual trips. I find the trip computer is about 2mpg on the optimistic side.
I also tow a boat, which involves slipway hill starts when recovering it; even with this, I have not suffered from the problems with the Dual Mass Flywheel which have been reported by others, and the vehicle has now covered 71,000 miles (I am touching wood and have my fingers crossed!)
Problems to date have been one failed door lock (LH rear, fixed under warranty,) a broken dust cover on the rear hatch catch mechanism (fixed under warranty and a design fault I suspect,) and it now has a temperature sender problem which needs fixing, but does not affect things greatly it seems. Not too bad for a vehicle coming up to 6 years old (end of May) and with 71,000 miles under its belt.
Oh, and performance towing is excellent, with maximum torque at 1900rpm; it is capable of surprising some so called 'better' tow cars for both acceleration and uphill.
Good luck if you decide to go ahead and buy it.
Enjoy your holidays,
Trevor M
Jul 25, 2007
293
The Golf will certainly have enough weight and power, but estates (and saloons) tend not to be as good for towing as hatchbacks due to greater overhang. I have never owned a Golf Mk4 but did own a Skoda Octavia that was mechanically the same. Great car in most respects but the engine management electronic system was very unreliable. In 2 years of ownership it was in the garage 8 times getting various electronic engine sensors etc replaced. All these parts were VW or Audi badged! Other than a Renault I drove before I was married the VW group car was the most unreliable. Despite the boring image, I have had by far the best service from Fords (Escort, 2 Fiestas and 2 Mondeos).
May 21, 2008
102
Hi Jago
Our tug until we recently sold(!) it to our daughter was the car you mention. Similar experience to Trevor M. Only things that went wrong in 80k miles were replacement discs on the back (or was it the front?) wheels. Cam belt + service cost
G
Guest
Im fairly sure when I had my 51 plate 2.0DTI LS which was a bog standard company hack its kerbweight was just under 1400kg?
The Vectra did 130,000 is its 3 years with me and never missed a beat (but did use some oil).
