Grey Blotches on hatch covers
Jun 7, 2005
727
I know this subject has been covered before, even the Fenwicks web site explains what it is and suggests a way of getting rid.
However I have tried all these cleaning solutions to no avail, might as well pee on the affected area's (that didn't work either)for all the good I am doing.
Has anyone got a real solution for getting these area's clean, surley their must be a product out there that actually works.
Over to you Joyce!!!!!!!
LMH
Excuse my ignorance Graham but what are hatch covers?
Why don't you get in touch with Kim and Aggie? (How clean is your House? - Channel 4).
Lisa
Jan 2, 2006
2,431
If you mean the plastic surround on the locker doors like the battery compartment and the loo door then I clean mine using what used to be called Jif and water.
Jun 7, 2005
727
Plotter
I tried cif but to no avail.I even tried a small area with T-Cut.
I think I will have to resort to a re-paint
This is what the Fenwicks web site says
Q. WHY ARE THERE GREY BLOTCHES ON THE HATCHES?
A. The problem is caused by what appears to be a virus, this consists of grey blotches around the hatch which cannot be removed. It only seems to attack the hatches with the rough finish e.g. toilet door and battery hatch, it may be just a result of poor materials and exposure to ultra violet light.
Hatches can be best cleaned by using a toothbrush. Dip the toothbrush into the bottle of cleaner (or make up a 10:1 solution in a spray bottle), work it into the hatch. Allow to stand for about 30 seconds to 1 minute, run the toothbrush over the area once again (no need to add more cleaner), then rinse off. This will remove any dirt, grime, green etc.
Feb 11, 2007
575
Just a thought GrhamW, as i said jif/cif has always done ours and i use Autoglynn over the whole unit, however as it does not work on yours have you used something which has "attacked" the plastic top surface?.
