Habitation 12 volt electrics not working
Nov 29, 2010
59
I note another member has intermittent problems, I have nothing at all. No 12 volt lights, fridge, water pump, water tank capacity, battery condition etc. It's a CI Carioca 2005 644. Have checked fuses on the electrics control unit, unplugged and reconnected all connections on the circuit board similarly for the control panel mounted over the habitation door. The multimeter shows 12.7 volts coming from the engine and leisure batteries; not tried it with the engine running. Tried running from mains but same problem though the leisure battery was being charged 13.7 volts and the 240 volt sockets are live. Is it the circuit board and components? Can these be repaired as a new one costs £300 I am told by the CI agent and may take 6 weeks to travel from Italy!
Oct 8, 2010
46
I would suspect either a main fuse supplying the habitation electrics from the leisure battery, or the isolation relay (if it has one) that turns the habitation electrics off when the engine is running.
Andy
Nov 29, 2010
59
Have checked all the fuses I can find. I have also checked that power is supplied to the circuit board from both the leisure and engine batteries. No problems there.
I am not aware of any isolation relay on this van.
Oct 8, 2010
46
I'm not sure how the Ci system works, do you have a control unit that's separate from the control panel? You have power to the circuit board in the control unit but no power at the separate control panel? It could be a fault in the control unit or the panel, is the system made by Arsilicii, I think they supplied these for Ci. If so, there is some documentation here: www.arsilicii.com/eng/tuttidocumenti.asp?doc=autocaravan and they seem to offer support here: www.arsilicii.com/eng/Supporto.asp
Sometimes these electronic panels jut need resetting by unplugging them for 30 seconds. Failing that you'll need to get someone who is familiar with the Ci setup to take a look at it and advise whether it can be fixed or not.
Andy (wondering why motorhomes are so complicated these days...)
Dec 9, 2010
Hi. I have 2005 Rapido 786 on Ducato 2.8, Couple of weeks ago the control panel was flashing, bleeping alarm and causing lights to flash on and off too. I could hear 'click' in the fuse box every time the lights and control unit flashed on and off. All warning symbols on the control unit were illuminated so unable to read levels of water, battery etc. The 240v seems uneffected and we managed to finish our weekend away, albeit in the snow and with icicles from our noses as no heating. I popped it to local dealer and great young chap took a look, leisure reading was 13.3v but there was no increase when I started the van to indicate charging. He said best to get the van in for a checkover to see what it is.
Does anyone have any idea what I am in for? I rang another local dealer I have used who suggested replacing couple of parts (control panel and another piece) which could take 4 weeks to arrive AND cost over £1000. This is an astonishing figure. Please can anyone suggest what we might check out first. We are very amateur on the fixing and mending front, but I love my van and would love to find a potential cheaper remedy. Thanks for your help. Daphnevan.
Nov 24, 2010
11
Rapido.
It could be as simple as a fuse or perhaps a bad leisure battery connection. The display symptoms you describe are consistent with the "boot up" sequence of the electrical control system. Suggest you first check all the low voltage fuses associated with the leisure equipment, there could well be a couple situated in the engine compartment near the starter battery added by Rapido and it is very possible that one of these is the culprit. Don,t just look at them, check them for continuity with a meter after remoiving them individually. Check both leisure battery terminals for cleanliness and soundness. There could also be a fuse in the positive feed to the leisure battery. Disconnect the leisure battery negative terminal for acouple of minutes then re-connect. This should enable the electrical system to cleanly re-boot.
If you have not sussed it by then then you need a hands on sparky.
Take care
CC.
Dec 9, 2010
Thank you so much for your reply. We will check everything you suggested with fingers crossed. I cant get the van to a sparky till after xmas anyway, so nothing ventured nothing gained. will be a couple of weeks before I can get to the van as she is keeping warm in a barn, but thanks for the tips and have a nice Christmas . Regards Daphne .
Jan 16, 2011
To the original poster: Sorry to be negative but from experience I'd say its an odds on favourite that the control panel is kaput! I've just replaced one for a customer and it took five weeks to arrive.
DD.
Dec 21, 2014
Hello all, I know this is an old post but still crops up in the searches so still relevant. You don't have to wait 6 weeks for the unit to arrive from Italy, as stated above. Atlantic Motorhome are the biggest independent REPAIRER and seller of Motorhome Electronics and stock both remanufactured and new items for Ci and ALL Motorhomes at half Dealer rates. In stock are Control Screens, Fuse Boards, Charger units, etc. Those we don't have can be obtained from Arsilicii and Nordelettronica (we are agents for both) within 7 days. We can often repair the existing units at a fraction of the cost of New. We specialise in fixing Motorhome Electronic issues that are sometimes down to wiring, not faulty units.
We have the ability to repair Control Panels, Chargers and Fuse Boards. We are one of the few UK Motorhome Electronics repairers that also knows Motorhomes. We even ship items to stranded Motorhome owners abroad to help them continue their holiday.
Sorry long winded post, but we have a free email service where you can ask for advice/help, see : http://www.atlanticmotorhomeservices.co.uk/contact-us.php
Available is advice from someone who understands how the Electronics inside the Fuseboard actually works in your Motorhome. Not just understands the basics of Electrics. Please note this advice is available via email only, as you can appreciate it takes up a lot of our time .
516yuanyuan
BANNED
May 16, 2016
64
cartier watches for sale
ray ban sunglasses
new balance outlet
valentino shoes
gucci outlet
abercrombie and fitch
converse shoes
dior sunglasses
burberry handbags
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
mizuno running shoes
reebok outlet
kate spade outlet
lululemon sale
longchamp outlet
ray ban sunglasses
rolex submariner
coach outlet store online
stephen curry shoes
toms outlet
kate spade outlet
levis 501
michael kors bags
designer handbags
louboutin shoes
cheap jordans
nike free runs
adidas supercolor
nike roshe run women
hollister co
yeezy boost 350
burberry outlet online
adidas trainers
coach factory outlet online
basketball shoes
chaussure louboutin
versace
omega watches
michael kors outlet
cheap air max
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
vans outlet
louboutin outlet
ecco shoes
michael kors outlet clearance
ghd flat iron
sac longchamp
canada goose jackets
coach purses
coach outlet online
coach outlet online
adidas nmd
michael kors outlet
instyler max
oakley sunglasses wholesale
versace sunglasses
toms shoes
adidas nmd
prada outlet
adidas superstars
ralph lauren
air max 95
longchamp bag
chi flat iron
armani jeans
oakley outlet
reebok uk
true religion outlet
michael kors handbags
fitflops sale clearance
polo ralph lauren
lacoste outlet
cheap jordan shoes
ralph lauren outlet online
michael kors outlet
adidas nmd
nike store uk
skechers shoes
louis vuitton borse
rolex watches
ralph lauren uk
nba jerseys wholesale
christian louboutin
louis vuitton pas cher
nmd adidas
cheap nfl jerseys
sac longchamp pliage
yeezy boost 350
converse all star
hollister sale
michael kors outlet
burberry
ralph lauren outlet
lululemon outlet
oakey sunglasses wholesale
burberry uk
christian louboutin shoes
coach outlet
yeezy boost 350 white
pandora jewelry
michael kors outlet
adidas shoes uk
asics shoes
hermes belt
polo ralph lauren
kate spade outlet
yeezy boost 350
designer handbags outlet
lacoste shoes
adidas nmd white
toms shoes
supra shoes
bottega veneta handbags
nike air max
ugg outlet
supra for sale
gucci handbags outlet
polo ralph lauren outlet online
ray ban outlet
nhl jerseys wholesale
coach outlet online
michael kors outlet online
louboutin outlet
adidas pure boost
pandora charms
louis vuitton bags
cheap ray-ban sunglasses
michael kors bags
adidas superstar
cheap oakleys outlet
oakley sunglasses
burberry outlet
nike cortez white
nike trainers
nike air max 90
kate spade outlet
louboutin pas cher
nike tn
micahel kors
converse shoes
michael kors outlet
prada sunglasses
polo ralph lauren
hermes uk
cartier watches
adidas shoes
asics gel nimbus
mlb jerseys wholesale
converse
coach outlet
adidas stan smith
nike cortez
polo ralph lauren
louis vuitton outlet online
cheap jordans
air force 1
rolex replica watches
toms wedges
cheap ray ban outlet
polo ralph lauren
ed hardy uk
nike blazer
ray ban sunglasses
under armour shoes
christian louboutin uk
fitflop uk
coach outlet
jimmy choo shoes
nike huarache black
running shoes
cheap oakleys
jordan pas cher
valentino outlet
michael kors outlet stores
omega seamaster
fitflops shoes
ralph lauren outlet
cheap nike shoes
coach outlet online
coach outlet clearance
gucci borse
nike air max uk
michael kors outlet
ralph lauren pas cher
true religion
fitflops outlet
reebok shoes
ferragamo shoes
ghd hair straighteners
nike air max
cheap nfl jerseys
hollister
salvatore ferragamo
ed hardy outlet
wholesale nike shoes
ray ban sunglasses
true religion jeans
jordans shoes
adidas gazelle
nike huarache
michael kors purses
fitflops sale
vans shoes
jimmy choo outlet
ray-ban sunglasses
burberry outlet
yeezy boost 350 black
oakley sunglasses
fitflops sale
ray bans
oakley sunglasses
reebok
under armour outlet
ugg outlet
nike air max
bottega veneta
armani exchange
air jordans
michael kors handbgas
puma shoes
cheap jordans
babyliss flat iron
"Lowry scores 35, DeRozan has 28, Raptors beat Heat 116-89
TORONTO (AP) — Kyle Lowry scored 35 points, DeMar DeRozan had 28 and the Toronto Raptors beat the Miami Heat 116-89 on Sunday in Game 7 to reach the conference finals for the first time in franchise history.
Bismack Biyombo added 17 points and 16 rebounds for the Raptors. They'll open the Eastern Conference Finals in Cleveland against LeBron James and the Cavaliers on Tuesday night. Toronto fans chanted 'We Want Cleveland!' in the seconds.
Pause
Current Time 0:00
Duration Time 0:00
Loaded : 0%Progress : 0%0:00
Fullscreen
00:00
Mute
DeMarre Carroll scored 14 points, and Patrick Patterson had 11 to help the Raptors become the 15th team in NBA history to win two Game 7s in one postseason. Toronto beat Indiana in the first round.
Dwyane Wade and Goran Dragic each scored 16 points for the Heat. They were denied the opportunity to renew acquaintances with former teammate James in the conference finals
But after Toronto dominated the Heat in the second half and rode the superior play of Kyle Lowry and DeMar DeRozan to a 116-89 romp, the Raptors won the series 4-3 and advanced to its first East Finals. For once, they did not underachieve. They played like a team that had won 56 games in the regular-season. They’ve been in existence since 1995-96 and had been out of the first round just once before this spring. Before Sunday’s rout of the Heat, they had been mostly known through the years for losing big playoff games, often at home.
So Canada loves it, but basketball fans won’t be able to see the Heat try to exact some revenge against James for leaving Miami two years ago as a free agent. Even James admitted during the second-round series against Atlanta that he wanted to play Wade, his old teammate, for the right to get to the Finals."
gtrrth
