halfway to spain?
Dec 14, 2006
3,205
Have you worked out which route you'll be using? There are so many alternatives that it would help to know which roads you're planning on using before recommending sites. You can use one of the route planning websites such as mappy.com, or viamichelin.com to look at alternatives, or do it the old way with a paper map (which is what we do). The tolls on the autoroutes can add up, and the route planning websites will calculate the likely costs for you - be sure to select 'with caravan' if you're towing as the tolls will be approximately one third more with a caravan.
We generally do Calais(or Dunkerque), Abbeville, Rouen, Chartres, Clermont Ferrand, Millau, Perpignan and then into Spain - but others recommend using the A20 and going around via Toulouse, then over the border at Bourg Madame. We've always had two overnight stops though, so we can arrive at a decent time to set up in daylight! We generally stay overnight somewhere around Salbris/Nevers and then again around Millau/or down towards the Mediterranean.
G
Guest
Depending on your boat time Clermont Ferrand is a days towing from Dunkirk or from Ebro Delta the other way using virtually the same route Val describes.
Oct 12, 2009
16
thanks for the advice.probably decide on the day if one or two stops.we have very early ferry.
