hanging rail in shower
Apr 1, 2007
146
We have a van with an end washroom and a large separate shower which we tend to use for storage. I was wonder if anyone has fixed up a telescopic shower rail across the shower cubicle, in order to hang wet items of clothing and, if so, has it been successful?
I have seen some quite slimline poles that I thought might do and, being telescopic, there would be no need to drill holes in the plastic covered walls.
Aug 15, 2007
42
hi yes i have, i used an old expanding shower rod cut to about an inch longer. cut the rubber suction ends down to fit the channel and it works a treat, it holds two towels and can be removed very easy
hope this helps
bill
Dec 14, 2006
3,205
We've a fixed bed van, with side washroom, with blown air heating, and have fitted a rail across, just as described - ours is spring-loaded so it stays under tension. It's great for drying off damp towels if you put the blown air heating on.
