Help locationg spare parts pls?
May 15, 2016
114
I want to replace part of the rubber strips/beading that cover the screws that hold the edging in place (what's it called). I took the rear light cluster off and the metal gromet that is fitted in the shell that holds the screw, has rusted away, again what is it's name and where can I source replacement parts please?
Oct 8, 2006
2,038
717
Try the Caravan Surplus Store at English Street in Hull - unless you can get a spare from the manufacturer parts dept.
937
It is not really clear what parts you are after.
Re the cover strip, do you mean the strip which sits in the awning rail? If so, that is a Herzim Strip and comes in different sizes, and colours.
The light, what bit are you talking about, the actual lens cover or the rubber grommets in the caravan body that the screw goes into?
May 15, 2016
114
Thanks. That'sthe 1st question answered. It's the Herzim Strip. Your asumotion is correct. I think mine are metal, but it's the grommets in the body I require. Are they simply called grommets?
937
Glad your first question is answered.
Now for your second.
They are called Well Nuts
