Help with Avondale Argente 480/2 2007
May 27, 2015
just purchased the above caravan, and apparently I need a pump that goes into the aquaroll. Does anyone know which one I need? Also type and size of gas bottles? I don't pick the caravan up until Friday but going away in it on Friday too! Please help? Thanks
199
19,235
My Avondale has the one in this advert:-
Sorry - the link didn't work. Look at ebay item number 201340116785
5,136
Congratulations on your new purchase. No doubt the seller has shown you how everything works? Perhaps water and gas excepted?
Do you know when the Avon dale was last serviced. Please at the very least check the condition and pressure of the tyres before your Friday departure.
Good luck
1,818
Our 2008 Argente which was more or less identical had an on board pump so I wpuld think yours should be the same. Not sure who told you you needed a drop in pump but double check. You normally get the pump with the caravan so not sure why it should be missing.
I would speak to the seller and if you need one establish what it is from them. If a dealer is selling the caravan they should have them in stock as there are only a limited number.
May 27, 2015
Thanks, your right it has an on-board pump. that helped a lot thank you. Do you know which hitch lock i need? Also any recommendation on wheel clamp to satisfy my insurance company? Thanks
1,818
The caravan will have an ALKO hitch. Check which it is and you can then get one to fit that model.
My feeling is the standard Nemisis is as good as any, like most though it is heavy. The newer Nemisis Ultra is very secure, lighter and far easier to fit. Whatever you buy make sure it is sold secure gold.
May 27, 2015
Thanks for your help. I will check which hitch it is. Is it marked or abvious which one it will be? Thanks
