Help with Lunar ariva 2001 manual/awning size
Hi All,
I have a Lunar Ariva GTS 2 berth 2001. I'm hoping someone out there either has one or a manual for one.
I'm buying a full awning for it, there's a couple available near me but my van is an hour away so I can't check it. The Internet has 3 different ideas of size for my van from 780 to 810. Which makes it 2 different awning sizes.
If anyone either has the van and can measure ground to ground around the awning channel, or has the handbook that lists for the same model, I would greatly appreciate it.
Hi All,
That is a really old caravan and there will not be many around. You may need to do that hour;s trip?
I know it's a long shot. I'm back tomorrow anyway so I can measure up, but then I can't get the awning 😁 I know it was unlikely.
Once you have measure up, an awning in that size should not be an issue. Do you really need a full awning as most porch awnings will fit your caravan?
I have a porch awning already, just enough for shoes and a bin really, struggle for space and it's an arse to fit but it will do for now. Thinking if I get a full awning it will give me a bit more space, and one for sale near me appears to be 1 size too big. My van is 785cm and it's an NR Pullman (I think) size 7 so a bit on the loose side... I'll keep looking but I'm tempted to deal with the slightly too big one for the money (£160 with annex).
I would keep looking one might come up that will suit your caravan good luck
