I've recently installed a 120w solar panel and victron regulator. I found the prewired loom behind the microwave and connected everything up. Everything appears to be working as it should, except the swift command display panel. Its showing that I'm drawing 12.1 amps, and producing 25.5 amps. The unit is stuck at these numbers no matter what I do. Disconnect the panels, or the wires from the controller. I have even changed the battery, which has not cured the problem. The correct figures, are shown using the victron, but it's annoying the hell out of me not having it working as it should. I've seen many installation videos on you tube using the exact same products and no one has had this issue. Please see link for photos
Help.
Help.
