4,479
Google and this is a very common problem with this Milenco model.
Suggestions offered:
Key not fully inserted.
Try spraying order or silicon over the entire lock. Don’t use wd40 or oil
Try gently wiggling the key to and fro in the lock.
Hope you succeed. Let us know the end result 👍
Reactions: borderbilly
1,780
That’s unfortunate, so I await Mel’s considered advice.
Assume you’ve used penetrating oil, and/or light tapping around the lock area.
In our case we hit it with a hammer. Not sure that will help here; although could try tapping the key?
Locksmith?
718
454
635
Locksmith?
If it doesn't open, I will cut it off myself, or find those people who lift anything, the unmentionables, too tight to pay a locksmith, I am a Jock after all.
