Hi, i have a senator wyoming twin axle. Ive noticed if im running water from the hog, ive got a leak on the outside of the van. Could this be a seal ?
Jan 18, 2023
I can see water running along the bottom edge of the van. Seems all dry inside. Could it be the seal where the outside pump clips in. Tia πŸ‘πŸ‘
Jan 22, 2021
9
11
4,515
Could be a worn O ring where the pump plugs in. Replacing it is a matter of a couple of dollars (I'm in NZ) and put a dab of food grade silicon on it...Peter
Reactions: sully
Jan 19, 2002
1,710
551
Presumably it is dry when the taps are off and the pump not drawing water, but can be seen to leak when one of the taps is on and activates the pump? Also may be over simple but check the plug and socket are clean and held in place by the flap at 90 degrees when fitted.
