3,145
Hello Sandra,
Welcome to the forum.
To try and answer question I need to ask for some clarification, Which hinges? There are several different hinges in most caravans, and choosing the right hinge depends on what job its expected to do. However most of the internal hinges are nothing very special, and you could probably replace them with ones from your local DIY store. I would suggest you go for plastic or brass or stainless steel as plain steel hinges are very likely to start to go rusty while the caravan is in storage. Another option would be to visit your nearest ships chandler (do you have a canal marina nearby?) Marine hinges will be very good indeed but they will be quite expensive.
a trip to your local caravan dealer may help to source replacements, or if the hinge is well hidden, you might find a suitable type at you local DIY
Now I cant comment specifically about the hinges Abbey use, but I would expect them to be very similar to be surprised
