Hitch Problem.
Oct 22, 2009
586
5
18,885
Hi y"all, this is our problem. After reversing the van onto the drive the rubber boot and ram retracted and will not release unless we chock the caravan wheels and pull against the chocks. The hand brake is off.Any and all advice much appreciated.We have a Winterhoff stabiliser and a t/a van.You have always been able to sort us out before so thanks for that again
Thursdays Child
Feb 3, 2005
532
Hi Thursday's Child
I've had this happen from time to time. All that is normally needed is to put on the handbrake and then just let the car run forward a few inches. Obviously if you are still on a slope you need to make sure the van can't run away when unhitched - in which case I would wind the legs down as well.
936
With the van unhitched, try pushing the drawbar inwards(will require some force) and then see if it slowly returns to its normal resting position.
If it does not, the hitch damper has failed and needs replacing
Jun 6, 2006
931
197
18,935
Or following on from Damian's post.....
it could be that the hitch shaft is bent, thus sticking, but Damians post would be the to follow in the first instance
