Can anyone tell me what setting to switch my fridge to when towing so it'll be cold on arrival at the site? Is it battery or electric? Thanks
angel3 said:Can anyone tell me what setting to switch my fridge to when towing so it'll be cold on arrival at the site? Is it battery or electric? Thanks
Dodger524 said:angel3 said:Can anyone tell me what setting to switch my fridge to when towing so it'll be cold on arrival at the site? Is it battery or electric? Thanks
Our 'fridge takes it's pick of whatever is available, 12 volt being the least favourite choice.
Bear in mind that the 12 volt option only normally works when your engine is running and can be problematic with Euro 6 engines.
Dodger524 said:Bear in mind that the 12 volt option only normally works when your engine is running and can be problematic with Euro 6 engines.
ProfJohnL said:Dodger524 said:Bear in mind that the 12 volt option only normally works when your engine is running and can be problematic with Euro 6 engines.
Please enlighten me as to what problems the Euro 6 engine causes with the fridge on 12V?
Dodger524 said:ProfJohnL said:Dodger524 said:Bear in mind that the 12 volt option only normally works when your engine is running and can be problematic with Euro 6 engines.
They often don't work for long because the Euro 6 charging system depends on regenerative braking and therefore does not fully charge the car battery. The result is that the leisure battery can discharged by the fridge to the point where the fridge stops working.
Martin24 said:we opted not to have the optional stop start .
Woodentop said:...Can someone also enlighten me (if not the group as a whole) how regenerative braking works on a car? A bus or truck yes as they often have specialist additional kit fitted, but I have never seen or heard of it on a car.
Jaydug said:Martin24 said:we opted not to have the optional stop start .
When my daughter put her car in for warranty service a few weeks ago, she was lent a model with stop start. Her six mile journey home took her through ten or so major roundabouts in busy traffic. She found the stop start very annoying each time. But what must it do to the starter and battery? At £800 for a replacement it doesn't bear thinking about.
Raywood said:Jaydug said:Martin24 said:we opted not to have the optional stop start .
I agree the battery point. Our car and my daughters were the same age and with similar mileages. Hers with the stop/ start needed a new battery after about four years and ours was sold after four and a half with the original battery. If that is typical then I am not convinced by the saving although i do have to say she did a lot more driving in the rush hour than us.
Having got that myself now I do find the engine can be caught out at roundabouts where you need to set off just as you are about stopped. At that point the engine seems to turn off and needs a short break before it will get going again.
