@charlesdobson I take your point about the higher pressure pumps , but with the flow at the tap reduced, the pressure in the boiler will be higher and reduce the kettling effect . A shower takes less water per second so the pressure in the boiler remains high .Your posts are slightly confusing/contradictory - just to clarify
. the water temperature is poor at the taps , but OK at the shower in the colder weather OR the shower also struggles ?.
If the former then it definitely flow rate that is limiting the temperature, if the latter then there may be a fault with the boiler controls .
What model of Imass do you have as on one it mentions water from an 'onboard tank' which would provide a supply of 'prewarmed' water which could be an option to fit inside your caravan
