Indicators on cars
3,890
Is that also the claim for the next to useless ornamental front fog lights? Not sure, but I think on many cars then headlights need to be on for the fog lights to operate? I have not driven in thick fog for a number of years and have to admit I have no idea how to switch them on as have not bothered to check. My bad!
I've no idea how "most" cars are wired but the whole point of foglights is to use them with headlights off, otherwise the reflected glare defeats the object.
Reactions: Hutch and Jcloughie
5,551
On what basis then is the condemnation of them determined?
I have over the years a lot of fog, mainly night time driving experience.
My preference is driving on dipped driving lights, only in quite recent years have I had dedicated fog lights as well.
This depends IMO on whether discussing the front or rear variants, the rear, again IMO clearly are, the fronts where mine are placed right down on the front spoiler well below the day time and parking and driving lights, IMO are primarily there to help my driving vision.
But as the Prof has explained Fog and its water droplets reflect and refract the light. They have never helped me see any better. At best I found they illuminate virtually nil
5,505
I spent many years on the road in my younger day clocking up thousands of miles and mainly motorways. Even a former traffic officer on this thread states they are useless and he should know better than any of us mere mortals.
2,786
On many cars nowadays, the low level fog lights also work with the steering, coming on to illuminate a corner. I had them on my last car. Complete waste of time. They can also cause confusion to other road users. I saw one the other day that was operating on a nearly straight road. His fog lights were flashing with small turns of the wheel.
3,930
1,121
......I'm with Hutch and JTQ and some what surprised that many find front fog lights useless.
Fo me front fog lights are to assist you to see better in foggy misty conditions.
They are designed to give a wider and much flatter beam that adds to the beam pattern of dipped headlights.
The full benefit comes to drivers who slow down in such conditions as they do nothing to aid distant forward vision.
IMO they should be called wide angle lights!
......also IMO rear fog lights should have been limited to only one light placed on the centre line of the vehicle's bumper.
Then no confusion with brake lights and only the last vehicles up ahead in a queue would have their fog lights visible to those following.
The one rear fog light in the centre and low down, is used on my current Swift caravan.
Reactions: JTQ and Hutch
9,578
Well that doesn’t work that way for my Kia, Toyota or Subaru. But I can’t think if I would have had headlights off even when I fitted the yesteryears cars with Hella fogs and long range driving lights. Headlights have to be on before rear or front fog lights are enabled. But surely you would drive with the headlights on dipped beam in fog irrespective of whether you had front fog lights or not. As full beam just reflects back on you, and the dipped beam can be of some use.
Reactions: JTQ
4,804
On my Santa Fe, you can have the front fog lights ON, with just the sidelights and DRL's this works very well in fog and mist, the main Beam lights reflect back from the mist.
Reactions: Jcloughie
3,890
I've generally found that front foglights plus sidelights gave the best visibility in fog or falling snow - they're mounted lower down which reduces the relected glare - BUT - I'm going way back using Cibie Oscar or Wipac rectangular foglights - in those days dipped beam wasn't good even with Wipac Quadoptics.
My more recent cars with built-in foglights have also had "projector" headlights with a flat Z-beam - perhaps why I don't rate modern foglights.
My VW Touareg uses the front foglights as turning lights, useful at slow speed but prone to passers-by stopping me to say one of my foglights isn't working!
19
8
1,515
When Vauxhall changed from trafficators to flashing indicators in 1955 with the Cresta/Velox/Wyvern, there was an article about it in the Vauxhall magazine. A road safety expert said that for safety reasons flashing indicators should be positioned a good distance from other lights in order to be clearly visible. This seems like good advice !
On the fog lights subject, I think they are good for showing up potholes in the dark as they are mounted lower down !
4,465
Strictly the lights that operate when you turn the steering wheel are not front fog lamps they are selective side illumination and are governed by different rules. Fog lamps are specifically designed for use in fog and other times when the atmosphere is loaded with particulate or water droplets which impair visibility.
2,786
My handbook on that particular car was specific. According to MG they are fog lights and they illuminate when the fog light switch is operated .
They may therefore be dual purpose.
Google AI, (which may be incorrect), states.
AI Overview
Learn more
How to Turn On Fog Lights (Plus, When to Use Them)
Some cars use fog lights as cornering lights, activating them when the steering wheel is turned or the turn signal is engaged, especially at low speeds. This feature illuminates the area diagonally in front of the car, improving visibility in turns and helping to identify potential hazards. However, fog lights are primarily designed for use in low visibility conditions like fog, and using them as cornering lights is not a standard function on all vehicles.
Elaboration:
  • Cornering lights:
    Some cars have a feature where the fog lights, or a specific bulb within the fog light assembly, act as cornering lights.
  • Activation:
    These cornering lights activate when the steering wheel is turned or the turn signal is used.
  • Low speed usage:
    The cornering function is typically designed for use at low speeds, such as when navigating city streets or roundabouts.
  • Improved visibility:
    The cornering fog lights illuminate the area diagonally ahead of the car, providing a better view of potential hazards in the turning direction.
  • Alerting other drivers:
    The activation of the cornering fog light can also alert other road users to your turning intentions.
  • Not a universal function:
    Not all cars have this feature, and even if they do, the fog lights might not be the primary source for cornering illumination.
Reactions: ProfJohnL
4,465
AI Overview
Learn more
Elaboration:
  • Cornering lights:
  • Activation:
  • Low speed usage:
Even here the turning light is identified as a separate function to fog light. The turning bulb happens to share part of the fog light assembly.
3,890
They can be designed for both functions.
There's no separate bulb for the two functions in my Touareg's case - the two functions are handled by the canbus switching.
The higher trim versions of Touareg also have a cornering function built-in to the main beam lighting - brilliant on fast twisty roads.
9,578
Prof this is an AI generated answer and it covers itself by saying that some may have a separate bulb within the fog light assembly, so that leaves it open for the fog lights to act as cornering lights.
2,786
It says ‘or’.
But your point is taken, different function would normally be designed differently. But manufacturers will attempt to combine functions and use them as cost saving while at the same time providing the opportunity of selling points.
My car has neither front fog lights or cornering lights. I I don’t miss them.
115
51
4,635
To my mind front fog lights are a complete waste of time, ESPECIALLY when it's dark and foggy.
I disagree. I once had to pick up my dad from nearby train station on a freezing cold foggy night driving along a small B road by the side of a quarry. If it wasn't for the powerful fog lamps on my Capri 2.0 S lighting up the road either side I'd of ended up where they built Bluewater shopping centre. My dad cheerfully commented all he could see was a slight blur from my headlights and two beams of light underneath.
9,578
I fitted fog lights and long range spots in my early cars as the headlights were so poor, and yes thevadditional lights were of benefit. But you are not comparing like for like wrt modern cars with fog lights.
Jul 29, 2022
115
51
4,635
On Thursday travelling to Worcester hospital up an incline there was a small car behind me riding right on my rear bumper and driven by a lady. On coming to the round about which has two lanes, one for going left and perhaps straight ahead and the other one for straight ahead or right turn.
The lady indicated that she was turning left while I was on the outside lane going straight across into the hospital. Going into the hospital straight across from the nearside lane was practically impossible due to layout of roads into hospital.
I proceeded to go straight across, but then nearly had a collision as the lady driver on my left pulled forward as if to go straight across. I saw her out of the corner of my eye and got ready to slow down or brake to allow her entrance to the hospital. However she then turned right across the front of our car causing me to brake harshly even though I was probably doing less than 10mph. Still not sure how I missed not hitting her as the Lexus would have severely damaged her car.
Goes to show that even working indicators are useless if the driver has not understanding of the road rules.
Be honest, you just wanted to tell us you drive a Lexus😉
  • Haha
9,578
My ex SIL’s mother had a Lexus IS 200 bought in 2000 and still owned by her now, with full Lexus service history and in excellent condition, and virtually trouble free. But I really upset her when I commented that when it was first introduced it was the Toyota Altezza.
3,890
In Japan, quite a number of cars are sold under different brands with just a change of badge - this is to support different dealer structures - a bit like BMC without the grill changes.
9,578
I've been under the impression that Lexus was the luxury arm of Toyota
They are, and although some aspects will be common Lexus are not just a rebadged Toyota. The one I was referring to in my post was a model initially introduced by Toyota in to Japan then marketed worldwide as a Lexus. But irrespective, of its DNA it’s given 25 years of impeccable service and still looks good. The owner hasn’t fared so well. 😱
