I'm 75 and in need of renewal or a trade in...or so my wife tells me.
But is it the van or you she wants to trade in?
That is very difficult to be precise about, Obviously they are all usually designed to last at least the warranty period, but some components may wear out when they are used, but others may have poorer durability when they are not used for example a steel burner bar in an appliance may run for years if used regularly, but allow it to stand and damp can cause it to rust. and that is a very significant issue with caravans where they are used infrequently.U.K. or German most of the fittings are common to both!
Does anyone have any data on how long the heating or water heating system will last in hours?I doubt the kit in Tourers was ever designed for 24/7 365 use? I may be wrong🤔🤔🤔
I think she would probably get more for the 'van than a broken down old f.rt like me .TBH.
Although, as yet, I don't suffer from damp.
We had our caravan for about 2 years before moving into it for 2 1/2 years and then we kept it for another 4 years before selling. No issues with things failing. BTW the new CRA 2015 does not stipulate that you cannot use an item 365 days a year.I know someone who lives full time in tourers but change them every two years after that they say things start to fail.
My comment was a bit tongue in cheek and you are correct however on many products the marketing spiel never mentions important points like it should not be used 365 days a year. You only find this out when you read the owner's manual after purchase. We never had any issue with warranty work despite living in ours for 2 1/2 years and that was under the old Sale of Goods Act.The CRA is not product specific, so of course it does not suggest there is a usage limit. But if the specifications of a product or contract do include or exclude a particular usage pattern, the CRA will support it.
For example sleeping bags are often sold as Spring & Summer, Spring Summer& Autumn, Or Four seasons bags. Using a 2 season bag in winter and then complaining it had insufficient insulation in winter would not be supported by the CRA because the customer had not checked the product was fit for purpose by reviewing the products specification. That is a customer failure not a product failure.
Why?At the very least one should be looking at a twin axle if deciding to live permanently in a touring caravan.
Interesting ProfWhy?
I can't think of any reason why a TA would be better than a SA caravan. Its not size, becasue some of the largest caravans available are on single axles. They're not made differently, they use exactly the same types and strengths (and weaknesses) of material. What is your reasoning?
No need to explain a reason as it is self explanatory. There is no way we would have been able to live in our caravan if it was a single axle.Why?
I can't think of any reason why a TA would be better than a SA caravan. Its not size, because some of the largest caravans available are on single axles. They're not made differently, they use exactly the same types and strengths (and weaknesses) of material. What is your reasoning?
History has proven that some of the largest caravans have only had a SA. Some manufacturers choose to produce TA versions, but there is no technical or legal reason why so its probably to suit a buying public's preference, and so they can give the impression its worth more and charge more. They often don't make a big difference to the payload capacity.Interesting Prof
I am now left wondering why so many manufacturers make TAs?
That is just an illogical statement. There is no correlation that I can think of between the number of axles and the ability to live in a caravan. Size of caravan yes, but No of axles no.... There is no way we would have been able to live in our caravan if it was a single axle.
Humble apologies. I did not realise that you had lived in a single axle caravan for a couple of years and are speaking from experience.That is just an illogical statement. There is no correlation that I can think of between the number of axles and the ability to live in a caravan. Size of caravan yes, but No of axles no.
But size for size what is it that makes a twin axle better for long term static living than a single axle? I’m puzzled on this one too.Humble apologies. I did not realise that you had lived in a single axle caravan for a couple of years and are speaking from experience.
