Isolation question
Jan 2, 2008
178
I prefer to drain the caravan's hot water tank when I'm doing a long journey for weight issues. If I stop for an overnight stay I have to refill the tank and then drain it again the following morning if I wish to have water in the taps. As I am setting off on a journey through France which will entail 3/4 overnighters, is it feasible to isolate the hot water tank by using some taps or valves just for the one night stands? I know that I would only have cold water, but that doesn't really matter. Does anyone have any views or ideas? All contributions gratefully received.
Feb 3, 2008
3,790
Yes, you can buy inline valves which would do the job and which are relatively easy to insert. A couple of points to note:
1. How new is your van and will the modification invalidate any warranty?
2. Make sure you don't turn the water heater on with no water in the tank
Try your local supplier or CAK Tanks.
Jan 2, 2008
178
That's good point about the warranty as the van's only 1 year old. I'll check with the supplier. Thanks.
3,892
From a drained down status, simply don't open any hot taps when you connect the water supply and use cold water - then the air in the hot circuit will stay in place.
If your van has Alde heating then you can turn the water heating on with no water in the tank.
As pointed out put an isolation valve between the cold fill and the water heater.It will be plastic pipe so cut straight and push fit as easy as thatdata:image/jpeg;base64,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
TYcdPrWhyQfmTIP1B+ZMvNuA/cm8F6CAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg//Z
I would think they would be hard pushed to say it would invalidate your warranty?
