Jacking a caravan
I am new to this forum but NOT new to caravanning and I know that this topic will have been covered many times before, but I'm adding my own two-penneth to this gripe if only to vent my grievance. After recently changing my caravan for the 4th time in recent years, all used models by the way, yet again I have come across the issue of how to jack it up to change a punctured tyre. In the past I have carried a bottle jack and hoped for the best and fortunately never had to use it.........touch wood for the future! (Bottle jacks are fine if they are fitted with a "U" pad to help locate them securely under the caravan axle or, come as a kit that utilises brackets which again have to be fitted to the caravan chassis beforehand. In addition, bottle jacks require sufficient height to get them located correctly that is not always available after a complete blow-out). But, why oh why are the proper Alko jacking brackets not fitted as standard equipment, either by Alko during fabrication of their chassis or by the caravan manufacturers themselves? Most if not all, new caravans come with a spare wheel and sometimes even a side lift jack, but what's the point if you cannot jack up the caravan without these special brackets being fitted beforehand?
Now I know that many people would just call a professional breakdown organisation and let them deal with it, but if a puncture occurs in the depths of the back and beyond, {whereby we often are due to the nature of caravanning), well, we're stuck. I appreciate that many people may not be physically able or indeed don't want to trust themselves to manage a wheel change, especially at the side of a busy road, but there could be somebody to hand that might tackle it for them given the right equipment.
So, come on caravan industry, wake up! add the cost if necessary to the selling price and get these brackets fitted to ALL new vans.
An added point to my post above: The big caravan show at the NEC starts next week, (17th Feb.), if you intend buying a new van whilst there, I suggest you negotiate having the Alko jacking brackets fitted before taking delivery.
Most caravanners probably carry ramps to assist with levelling, so in the event of a puncture a ramp(s) can also be used to raise the punctured tyre so that a jack can be inserted. It would also aid removing the spare wheel if carried on the underslung Alko carrier, which I always removed anyway.
Reactions: JTQ
My 2013 Coachman 560/4 came with Alko Heavy duty brackets already fitted from new.
My previous 2010 Coachman 545 did not have the brackets.
You could always starting the jacking process with the corner steadies , slowly raising that side as the trail arm rotates down and the weight comes partially off the wheel that usually gives enough height for the botte jack to go under the axle bracket or even under the axle . The real killer is if you lose the whole wheel then most jacks will not go under the trailer at the recommend jacking points and you may find the motor mover is actually resting on the ground 😳
I have a 3 ton scissor jack with a ratchet handle that folds really flat and goes in a bag with an extendable wheel brace.
I find that this covers most eventualities.
I would never even think of going anywhere near the corner steadies
Going back in the 1970’s you could of done this as the steady legs were fixed to the steel chassis which was also double the thickness steel than present day caravans, Not to the floor as they do nowadays.
Best to have caravan attached to car when changing wheels as it won't move.
The corner steadies aren't designed to support weight of caravan, if jack gave out may end up damaging caravan where steadies attach.
