can i fit blown-air heating to a carver 3000S heater in my lunar premiere 417 year 1995 and where would i get the parts and imfo on how to fit it and is it hard to do thank you john
http://www.trumauk.com/Editor/assets/uk_08_06_pricelist.pdf[/quoteYour dealer should be able to supply the parts from Truma
Basically you knock out the disc in the back of the fire casing and the pipe draws hot air from there
You need to plan a route for the ducting and using a hole saw cut holes for the outlets.
The wiring is not very complicated but you need a wall switch/thermostat to operate it.
Have a look here
]http://www.trumauk.com/Editor/assets/uk_08_06_pricelist.pdf
thank you for your help and advice will look into parts from truma & fanmaster thankyou once again (JOHN G) & (GARY)Perhaps an easier way would be to fit a Carver mk1 Fanmaster, this was originally designed with being a simple to install upgrade in mind.
I can occasionally supply fully overhauled and warranted units at considerable savings on new prices. www.arcsystems.biz
