Keeping Battery charged during storage.
Nov 3, 2008
17
Can anyone advise me on the best way to keep by battery healthy during winter storage, as I have a Tracker on my caravan and it is connected directly to the battery. Is the best option to have two batteries and inter change every month, or is a solar panel best. If a solar panel is best what sort would I need.
Regards
Peter
I just use a 10 watt solar panel stuck on the roof of the caravan that I store in France and this is great for the job as it can be connected directly to the battery without having to use a controller.
If you do this, mount the panel with a slope, as rainwater will tend to wash any dirt off.
Nov 3, 2008
17
Thanks Rod. What make is your panel please.
Peter
Peter,
I can't remember the make now, and I only got back from France today, so I can't look.
I bought it off the internet and it came from somewhere in Hertfordshire. Try a Google.
Mar 24, 2009
353
Hi Peter, the Maplin "Solar" Trickle Charger does not mention a regulator and at this low charge rate I can't imagine one would be req'd
Mar 8, 2007
395
6
18,685
I believe a Charge Controller is only required for Solar Panels that have a 15W or higher charge rate and as the OP is only using a Solar Panel to keep the Battery topped up during storage, then as Rod suggests anything up to 10W should do the job in hand,
best regards, Martin
Nov 3, 2008
17
Many Thanks everyone for your help and advice. I shall be out and about this weekend buying a solar charger.
Regards
Peter
