We use a travel kettle, bought at a big caravan dealer back in the early '80s, still working well - it's 700w so takes it's time to boil a litre of water - but not much different to a modern 1kw kettle.A standard domestic one but with lower wattage than you would buy for a house. The “ dedicated” leisure ones are over priced and not that reliable. Bear in mind the current rating of your electric hook up. Power = volts x amps. So if you divide power by volts (240) you can get an idea of amps. Cannot remember precisely what make we last used, but it came from Argos. Think it was around 1 kw as a travel kettle.
When you're already lugging a dual fuel cooker, a dual fuel fridge and a dual fuel heater, the extra weight of a kettle is insignificant.Depends what sort of caravanning you do
Off grid. Gas / hob
Always with EHU. Electric
If you do both stick with a hob gas.
Why lug two kettles around
We had a Quest kettle for about 18 months which is why we bought the Swiss Lux.+1 Quest Kettle and is 800W, and there are plenty of low wattage models for you to choose
You are supposed to be drinking beer and not tea! 🤣 🤣 🤣As a back up I also have a hob kettle in case the electric kettle gives in due to frequency of use.
I have a pan that serves as a backup kettle, never needed to use it but no doubt I will one day.As a back up I also have a hob kettle in case the electric kettle gives in due to frequency of use.
We had the same theory, until we actually used the pan to boil water for teat and the taste was awful!!!! The (cheap) non-stick surface of the pan had obviously absorbed the flavours and spices of my wife's cooking over the years and decided to flavour the boiling water with it. We replaced all saucepans after that episode...........I have a pan that serves as a backup kettle, never needed to use it but no doubt I will one day.![]()
