Knott hitch damper
Mar 16, 2022
Thanks for your help I'm looking for the damper that conects inside the hitch and dampens the hitch when you pull off and brake
2,785
On the side of the damper should be some codes if it is like a standard gas strut, try Googling them. Worth a go.
1,332
507
As you refer to the caravan being aged around year 2000 I assume you aren’t quite sure of its age, there is a way to identify the age using the vin number, look up the 10th character of the vin number then if you Google “identify my caravan age” you’ll get a list of letters that tells you the age.
BP
2,785
Good find. However. I would still advise doing the research on any numbers written on the old unit. These are often in the form of length, diameter, meter, extension and newtons. But often much cheaper for the same product.
Or even use a configerator.
