Kojack Caravan Jack
Aug 31, 2007
5
Ok I need a little advice here.
I know the Kojack Caravan Jack is uded to change the caravan wheels, but do you use the jack part to help level the caravan i.e jack the side up and put a level block under the wheel, or do you just drive it up the block and use the level indicator.
Jun 6, 2006
1,037
254
Hi Chris,
I had to use the Kojack to level the van the other week, normally I just use the power touch but I had a fair height to get to on wet ground and the power touch just span on the tyres even with trying to walk the van up the ramp. If you use the jack you will have to go past the level mark on the Kojack level as they do not take into account the suspension on the van.
Hope this helps.
Martin "E"
May 17, 2007
9
Hi chris dont know weather you have one or not but watch out for the the touque setting on the bolts i stripped tow bolts when tighting them up. i checked the bar with another two and the same result was obtained
