Good evening, I would really appreciate if anyone who has towed with either a kuga 1.5 ecoboost or 1.5 tdci could give me some feedback on how they tow.
Many thanks
Many thanks
tcarper2 said:I use the 1.5 eco boost, with a coachman Olympia mtplm 1575kg. It is short on power and can struggle at times, I only get 20mpg. Previously I had a 2.0l Deisel. 160. I now wish I had stayed with the Deisel as it was much better for towing, I was getting 25mpg. I would go for the Deisel, but the 2.0l.
Les
carper2 said:I can only compare it with the 2.0l Deisel. It drives ok solo but the mpg is still poor about 28mpg. The big difference I notice is the engine sounds like a whine rather than power.
Les
ProfJohnL said:You cannot judge the ability of an engine on it'st cubic capacity alone. Its the power and torque characteristics that will determine its ability.
seth1 said:ProfJohnL said:You cannot judge the ability of an engine on it'st cubic capacity alone. Its the power and torque characteristics that will determine its ability.
Where do you think the power and torque come from?Basically what your saying is size has no bearing on uengine output.Absolute cobblers,please read what forum members are posting,read Mottys blogs.Take a good look at Renaults statement on their R9m engine.
Thats correct otherclive it has been well covered to say the least,so i cant see why JL has to constantly remind people of his beliefs.GStockton said:My Brother has had 3 Kugas all auto. First one a 163 bhp Diesel was fine. Second one a 1.5 turbo petrol with 182 bhp, he only had it a couple of months because of its poor Fuel consumption of 30 mpg and only 16 mpg whilst Towing!!! It had to go back to Ford, Who changed it for him for a 2ltr 180 bhp Diesel which he is now happy with. His caravan weight was around 1500kg.
It would be helpful if at least the information you post was correct.The 2litre VAG lowest output is 140hp,but leaving that aside and not being padantic the engines sizing is already of 2 litres.Quite a common and average size for a passenger car diesel engine.ProfJohnL said:Just as an example look up
1.pdf]http://www.lister-petter.co.uk/documents/product/en-LPG[027-08510]1.pdf
On page two you will see a table that sets out the Cubic Capacity of these engines and their respective power outputs
The 1800cc model produces 45 bhp at the flywheel, By means of a comparison the old BMC A series engine of 803cc was available with a power output of between 28 and 94bhp Smaller CC yet more power in some versions
VAG, make extensive use of a a nominal 2.0L diesel engine block. It is available with power outputs from 90bhp to over 180bhp - Same swept volume
This shows you cannot determine the towing capability of a vehicle simply by looking at its Cubic Capacity, you have to also look at the power and torque curves.
If you have two engine options, one small cc and one larger cc and provided the power and torque curves and the gear boxes are comparable, both will tow equally well.
