landrover discovery
Jun 22, 2005
22
Hi
Could somebody point me in the right direction
on the discovery towbar there are four sets of holes
which set should i use to tow my Baily Pageart Bordeaux.?
Jul 25, 2005
164
rob,
I'm surprised you have not received a reply to your message. It can't be just me that has not gone away for Easter?
Hope this info helps.
The drop plate directive 94/20/EC specifies that the centre of the tow ball should be 350 - 420 mm (13.8 - 16.6 inch) from the ground when the vehicle is laden to max weight.
Lower is better ( nose down).A drop plate must never be used to raise the height of a tow ball.
All measurments taken on level ground as usual.
Best of luck,
Pop
Jul 12, 2005
1,896
either of the middle ones, I run mine on the 3rd up but it depends on the van.
Slightly nose down if you can
