large electric front roof opening
Jul 6, 2005
16
the big roof light on top of our van opens and closes electrically it is fine when you press to open but judders a lot when closing has anyone any idea I have sprayed W D 40 the van is a Bessacarr 550
thanks Jenny
May 12, 2005
470
Jennifer,
I dont think WD40 has much in the way of lubricating properties, it used for displacing damp and freeing rust,
try a good silicon polish, or awning rail lubricant.
good luck TONY A.
Aug 25, 2006
758
Actually, WD40 is a decent lubricant, but for this type of application try some "tri-flow" which contains teflon and is a better and longer-lasting lubricant. Available in aerosols (but not cheap) so a doddle to use.
946
If roof opening system has a cable drive, it's probably be due to a kink in the cable somewhere, in which case lubrication is not going to help very much.
Jul 6, 2005
16
Thanks for replies have tried silicone afraid it dident help
jenny
