I have a Bailey Auvergne, which has a leak in the rear corner where the side wall meets the rear of the caravan, I have removed some of the floor board where it meets the floor and that's where the water tends to puddle on the floor corner.. It seems to be running down the wooden batton that joins the side wall to the back of the van..but running on the side wall side more than the back of the van wall.. I have sealed the rear part of awning rail a year or so ago to fix an earlier problem which turned out to be the rear top red/white light and re sealed the rear small window for a leak also.. I have no water coming in to the van from a nearby roof light which hasn't been sealed recently but I have been told it could be coming in there.. water seems to be coming in when in storage when not quite level ( Rear part down more than front ) I have resealed as many screws as I can see apart from the lower aluminium strip running along the van which is riveted on. Any Ideas .. as the van is sighted and my car will not tow ..so very much a DIY job but at a loss to know where its coming in..Thanks very much
Here is a pic of the problem side..
