- Feb 13, 2024
- 1,050
- 662
- 1,435
What leisure battery charger do you guys recommend to charge caravan battery? Have a AA one but according to instructions it will take 100 hours to charge 100AH battery, dont fancy waiting that long.
It should be fine as long as you have reasonable ventilation, most sheds are quite draughty. You have a charger / maintainer which is designed to fully charge the battery then switch to 'float' mode and keep it fully charged. I've had a quick look at the instructions for your charger. It says that normal charging mode is limited to 10 days, float mode is unlimited. It's far better for the battery to keep it fully charged than let it drop low and then recharge it.many thanks for all replies, no hurry to charge it, yes there is still some charge in battery, just wanted to top it up in readiness for 1st trip. As you can see i am not clued up on electrics and its all double dutch to me. Will switch on charger again tomorrow as its in shed and i dont like to leave it on all night.
So close to 100 hours as predicted. Hopefully it will just have been very low when you started. It would be an idea to take it off charge and check the voltage for a few days if you have a meter to confirm that it's holding charge reasonably well. It should measure around 12.7v after standing for an hour after being taken off charge and shouldn't really drop from that in a week.Hooray! Went into shed today and charger was reading Battery Fully Charged. That was about 4 days on charger.
Just at the back of your mind remember it is only saying "Fully charged", that is it has as much energy in it as the charger can put in, and get it to that associated figure giving 12.7 to 12.9 volts [depending on chemistry and charger setup].Hooray! Went into shed today and charger was reading Battery Fully Charged. That was about 4 days on charger.
To what purpose?Check the reading again in the next 5 - 10 days.
The number of days is irrelevant. Purpose is to make sure the battery is holding the charge.To what purpose?
And why between 5 and 10 days?
You should have your multi meter set to 20 v DC. That setting is for reading AAA, AA and PP3 batteries.Took a reading this morning ( Wednesday)
