Locks not opening!
Status
Not open for further replies.
Feb 17, 2018
184
51
10,635
First time we have been away & had trouble with the locks on a Coachman.
Can't open toilet flush lock at all, & off side front locker lock, also being very stubborn.
Any tips on how to cure?
2,391
Lock lubricant? We used to have problems with a Hartal door lock. Lock lube kept it going.
Also, are they the original keys( i.e. not cut copies that are not quite right ).
928
119
4,935
I had a similar problem with the battery box, in my case the key was turning the lock barrel then when I pressed the barrel in nothing happened, the lock catch was not releasing from its body, the way round the problem was to use plenty of force when I shoved the barrel and at the same time pull on the locker door doing this solved my problem, I then filed the catch slightly and this sorted my locker problem,
4,845
Grizzly, make sure your using the locker keys and not the caravan door key. The door key is slightly larger and should not go into the locker and toilet flush locks.
Jul 15, 2008
3,941
1,147
Another one for lubricating the locks..........It's one of my regular maintenance jobs.
Jun 11, 2012
1,537
33
19,685
I had problems with our locker locks as well one of them I had big problems opening it When I eventually managed to open the lock that wasnt working I decided to take it apart ,simple job just had to watch carefully in case the spring flies out this is a simple job to do the mechanism had come adrift.its easy to put back but put it back with e generous greasing.That is of course yours is the same problem. I finished doing all of mine. 9 Years on still good
Sir Roger
4,845
When the red light in the loo comes on , take Bella for a Loooong walk. :p
May 24, 2014
3,687
765
Consider using powdered graphite rather than lube oil. It lasts longer. It doesnt seem to gunk up and attract crud as liquids do.
https://www.amazon.co.uk/C-Tools-T6283A-Graphite-Powder/dp/B003KN0AJK
Jun 17, 2011
826
27
18,885
Lubricate the locks as suggested and when open use silicon spray on the levers and catches.
Mar 19, 2024
HI, I have a Fendt 700, 2015. The door lock won't lock from the outside, I turn the key to lock it, but when I turn it back to the middle to take key out, it unlocks again.
Any help would be appreciated
Status
