Looks can be deceiving !
Oct 12, 2013
3,037
This weekend we visited Doe Park at Barnard Castle , lovely site massive pitches and even got shown round the farm and just missed the Lambs being born by 2o minutes , weather was a bit wet at the weekend & snowy but was lovely on Friday when we turned up but as the title says when we went to hitch up on Sunday morning I got bogged in and stuck but luckily enough two pitches down was a bloke with a massive Land Rover Defender with huuuuuge tyres on which pulled my van straight out to the gravel . How embarrassing , first time in 5 years I've been stuck !! There wasn't even any black left on the tires of the sidewall as they were covered in mud and then so was the van once we started getting going on the country roads straight up the front :blush: :angry:
Hats off to folk who help one another I and no 4 x 4 quips from the usual jokers !!
https://goo.gl/maps/qqHgkMiitt42
4,464
Hey Craig sounds like you typed your message after a few bevvies , as I Tend to do, but glad the trip went well.
:p
Oct 12, 2013
3,037
:p
Re read and a few bits edited i think !!
Oct 12, 2013
3,037
I also forgot the awning poles so could not get the awning up but as it happened the weather turned to nasty and wet on arrival and so quick set up .
4,464
You really have to get to Woosie Fest after all your are Knighted. :p
8,880
]https://goo.gl/maps/qqHgkMiitt42
https://goo.gl/maps/qqHgkMiitt42[/quote
I’ve even been stuck on CLs when I had four wheel drive cars. One was a Gen 1 Sorento with AT tyres and she wasn’t going anywhere with the van coupled. In the absence of assistance (none on any occasion) my method is to off load the noseweight to very light then drive it off with the mover. Sometimes I’ve spun the nose wheel around and reversed the caravan off. Once to obviate moving stuff around in the caravan and filling the flush and cassette tanks Mrs OC just got in and slowly moved aft until the noseweight came light. I have also used my griptracks to prevent nosewheel digging in.
Parksy
11,904
2,400
:p
I'd never have guessed! :p :p :p
May 24, 2014
3,687
765
I have a fool proof method of getting off in those conditions. I simply attach the caravan to a Shogun and drive off. There are 4x4s and then there are Shoguns.
Locking diffs can make a huge difference.
8,880
A really good idea having grass in front of the hard standing. The site could have at least made it a bit narrower so fwd could have put the driving wheels on the tarmac. Assuming they are long enough that is. Better still just extend the hard standing forwards it makes getting on and off so much easier. Assume the car was parked off pitch elsewhere as normal coming and going wouldn’t do much for the grass.
8,880
I had a Pajero 2.8TD SWB which was absolute ace off roading. Compared to my earlier Disco 2 the Pajero was streets ahead. It’s Super Select system was so easy to use. I did think about fitting front and rear diff locks but with a center differential lock and rear Limited Slip differential there wasn’t much fazed it especially with its 33 inch BFG mud terrain tyres.
I didn’t realise that the SG3 Shogun came with diff locks other than the centre one used as part of the 4wd locked mode. Have you had them fitted or were they an option?
Feb 23, 2018
916
87
18,935
I don't get why these 'island' hardstanding pitches exist. Surely the grass will get churned all the time?
May 24, 2014
3,687
765
My last SG3(actually the Elegance) came with them fitted, they had been an option factoy fitted from new. Unfortunately this one only has the centre but its enough, in four low with the centre locked, its fairly bomb proof.
1,818
Looks a nice site but those grass strips can be very difficult if the tow car has to set off on them.
Having rallied Landrovers in my youth I know there is little to match the Defender though.
Oct 12, 2013
3,037
It did this weekend and i felt terrible !
May 24, 2014
3,687
765
Spent enough time in the Snatch when I was younger. I prefer a vehicle with cushions B)
8,880
It would have been its tyres that did the trick. Any decent 4wd with tyres designed for more tha tarmac would have coped. Were the Defender comes into its own is its inbuilt off road ability with clearance articulation and 4wd. Saying that my old Pajero did help some out of tricky spots including D2, D3 and 4 too. Tyres, clearance and traction being the key to good off roading.
Oct 12, 2013
3,037
Out of respect I thought id park the next graveled pitch up so I didnt turn any grass up but my time was wasted on Sunday morning while hitching up !! :blush:
Sep 29, 2016
1,829
245
EDIT: My bad, should have read all of the previous threads
5,192
Some years ago on a PCv rally at Stowford we were all bogged in. Using our levelling boards under the jockey wheel and the mover was the only way out. None of our 4x4 coped.
Oct 12, 2013
3,037
Feeling much better !!! :) :lol:
Parksy
11,904
2,400
Mine did! It was a Mitsubishi Pajero (grey import Shogun) and using the trusty Super Select 4wd with minimum engine revs we were out and away. :cheer:
May 24, 2014
3,687
765
And another right thinking man. Well said, sir. B)
