Loss of Battery Power
Hi Guys I hope there is somebody out there that can help.
We have just bought a brand new Sterling Elite and no expence spared a new 110amp leisure battery to go with it.
After about five or six days the tracker tells me I have low battery power.
SEcond time this has happened ,first time we had left the TV amp on when leaving the van at storage thi stime we double checked everything and again in about 6 days its flat again am I missing something somewhere when parking up
Come on you Guys give Sir Rog a helping hand..
Get the charger looked at (diode failure),friend had the same problem on the same van and had the charger replaced,all ok now.
Hi Sir Roger,
We had exactly the same problem with our new Swift Challenger. I revisited our van in storage after leaving it for 1 month. The battery was flat at 3 volts. I attempted to coax it back to life but the battery was beyond help, it was brand new too. Anyway your charger unit is the same as mine, a Sargent. You need to switch off the unit with the on/off button, if not it will drain the battery. It is not that clear in the handbook, but Sargent did tell me this in an email contact. Hope this helps with your problem?
David
David . and Mikey many thanks for your replies I will check out both but will do the easy one first .
Sadly shmbo would not let me press the little on and off switch on the left of the Sargent box so that will be the next job
The salesman that sold us the van said no need to touch this box and switches at all , but have already proved that wrong
Regards Sir Roger
HI! Sir Rog. i had the same problem what it was that was draining my batt was the small switch for the fan of the space heater i forgot to switch it to off (middle of slide swith for the heater .just one idea .check yours
Cheers
Duggie
