I never thought of that james, good shout!!Hi Tornirsk,
Some hinges appear to have a nylon insert and I think it is best to stick with a Silicon spray as WD40 can have adverse effects on plastics. It,s fine if the hinge is all metal.
Regards
Jim
I was just goona dig a tin out to check..... Cant belive i am discussing w d 40 at 11 40pm sunday night ha haHi Danny,
I THINK that WD 40 is used to chase water away in those instances not as a lubricant. By the way, Lidl are selling their 'W5 silicon spray' on Mon 9th March at 99p a can.
I buy it a tray at a time whenever it appears.
Wd40 is more of a penetrating oil that has grown to be a spray it everywhere product.
we must be the last one awake mateI was just goona dig a tin out to check..... Cant belive i am discussing w d 40 at 11 40pm sunday night ha ha
Yeah........ Nite NiteI was just goona dig a tin out to check..... Cant belive i am discussing w d 40 at 11 40pm sunday night ha ha
thanks dustydog I stand corrected..........cheer'sDanny
WD40 is a duck oil, not silicon. Whilst it does free up and lubricate metal hinges it has a tendancy to dry out fairly quickly so in a few weeks you can be back where you started. Anything nylon / plastic is best treated with a silicon spray as suggested by James.
There are numerous uses for silicon in the caravan so we always carry a spray can.
Dustydog
Thank you all. Problem resolvedFirstly regarding WD40.
It is a water dispersant. The name comes from W(water)D(dispersant)and the 40 refers to its life span, 40 days.
It is basically paraffin with a posh smell, but after 40 days it then becomes a water attractant.
Hinges are best treated by removing the black plastic top cap on the hinge and applying 3in1 oil, and moving the door back and forth to work it down the hinge pin.
The plastic hinge covers can be removed by tapping gently upwards witha small flat bladed screwdriver at the round end part where the locating peg is.
If the caps are only the round type, again a small flat bladed driver will ease them up if you are gentle.
