lunar lexon 640 sb 2007
Aug 7, 2015
Hello people
I am a newbie here so rather green around the gills.
My problem is more in the need of advice. I have just bought a lunar lexon 640 sb 2007. what I want to know is what switches do what?. On the offside front seating there are 2 switches for the ultrastore I believe. 1 of them has a red neon that illuminates periodically when switched on. (does this just illuminate when the element is being used) the one next to it has no led or anything other than a rocker switch and fuse access (they look like fused spurs. I can work out the temp with the dials mounted on wall by door. the other switches are above fridge and are labelled master and pump. although the fridge light does not illuminate if I try to run it on battery whilst the EHU is plugged in. (12 v lights work with master switched down).Do I need the master switch off when travelling?. there is a reich twin axle mover fitted so if that is turned off with the red key should that just isolate the mover. Any info on the switches and what each does appreciated.
Steve
936
Post some pictures of the items please, makes informing you correctly much easier.
