lunar quasar 2017
Sep 2, 2023
Hi recently purchased our first caravan a lunar quasar 2017.
Can someone tell me what the 2 rocker switches operate that are under the locker next to front door.
I believe they operate the 2 wall lights and the mood lights under the windows and also the lights round the skylight.
Before anyone suggests trying the switches the reason I am asking is I am unable to switch these lights off unless I switch off control panel, they are on constantly. Don't know if it'
Any info would be greatly receiveds a problem with relay in the power supply unit.
5,498
Welcome to the Forum Stuart.
Has this problem just started?Or are you new to the Lunar?
Sep 2, 2023
new to lunar
when we got the caravan one of the 12v light circuits kept blowing the 10amp fuse.
After looking at various connections I disconnect the data cable at the rear of the control panel at the front door. when I reconnected the data cable the fuse held and the lights came on. However the lights that should be operated by the 2 rockers next to front door cannot be switched off. Even if I disconnect the switch completely they still stay on, only way to switch them off is to switch off main power at control panel. Only thing I can think of is a faulty relay in PSU?
Stuart
5,498
new to lunar
Stuart
Thanks Stuart. There are a few great electrical experts here. Not me on this one. But what you say tells a whole new story. Hopefully a solution will be suggested.
