Lunars poor design
Jan 29, 2024
29
41
35
Hi , just sharing info about my 2013 Lunar 490/4.
Today I had to remove the rear light / bumper panel and discovered a rather poor design . The aluminium rear panel does not run down to the bottom , but instead , stops roughly 4 inches from the bottom. In the photos you can see where the butyl tape failed and has allowed rain water to enter .
If the upper panel had been fitted to overlap the lower , then the water could have dripped off . The rear light panel had never been sealed at the top and a local caravan engineer assumed that this was because the back panel ran to the very bottom .
This caravan had previously a new bathroom fitted but the true nature of the leak was never repaired. I am now repairing the floor as water has entered at this rear panel , cassette toilet door and also a small crack in the corner of the shower tray.
Two weeks ago I had booked the van with this engineer who was going to repair the floor and fit a new water heater for £950.
At that time he had discovered the leaking cassette door . I later decided on doing the repairs myself.
4,253
Richard,thanks for this Forum thread, and I think this is the type of things things the forum is usefull for. It will help others as they repair their caravans, carry on with this . Great.
4,253
I have just re read your posting, about the shower. Tray. Recently I have used Capt Trollys, crack sealer,, in our shower at home, On using it seemed weak, but it worked well. £10 well spent.
Jan 29, 2024
29
41
35
I was going to try and find a replacement tray for this Lunar , but after removing the tray and realising who flimsy they are I decided not to bother . A good friend has offered to make one from stainless which will last for ever and ever .
Reactions: Dustydog and Hutch
4,984
Blame the cost accountants and the quest for shedding weight. Lunar always boasted theirs were the lightest. You can see why! Whilst a poor design feature the use of sealant at the factory would have helped as you point out.
Well done with your progress and updates👏👏
2,067
Thanks for the updates and well done with your project. Keep your friend well supplied with thank you gifts as, given the breathtaking quality of Caravans; you will need their help again.
Keep us updated
29
41
35
Hi , I resealed the rear lower panel with fresh butyl tape , a row of small stainless self tapers and sealed over with Sikaflex 522 . Refitted the light panel and side awning trims and sealed the top of the light panel with 522 .
Not the sort of job you would want every Saturday. Removing old butyl tape must be the worst job in the world ..
  • Haha
8,532
A useful addition to any toolbox is Captain Tolleys.
8,532
I was surprised at how many applications you had to make, and time lapses between applications, but it all went well. Save having to replace the shower tray.
I suggested it for the possible leak on the thetford locker door. Cheaper than £80 fir a new door.
2,475
Sounds like the plan has been well thought out and you are doing a good job with aid from a friend to complete your project. Looking forward to further updates on this .
Jan 29, 2024
29
41
35
Thanks , I never wanted a project .I bought this as I thought it was mint and a bargain . If it wasn't for bad luck I would have none. I have made pledge to the wife and kids that I can turn this around. Have already booked a park in August. Plenty of time ..
8,532
I'm sure that it will come together in good time for your holiday, and your wife and children will really enjoy the experience. Hopefully the first of many to come.
1,818
We had the shower tray crack. We were able to get it repaired with a thick additional coating that looks to have worked well and provides a better non slip finish.
