• Weโ€™re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. Weโ€™ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Mains power
My caravan has been standing for a year and when I plug in the electrics, all that lights up is the fuse lights ๐Ÿ™
Caravan is sterling eccles 584 sport
Any help/advice would be appreciated thanks
If you know are competent with electrics I would suggest starting with the Ehu cable,Check between live and neutral pins on the socket first,then you can go from there,good luck ..Gary
Presumably you are talking of the 12 volt fuses with the Green LED below them. If nothing actually works probably the leisure Battery is flat and only just enough volts to light the LEDs
What year?
Have you looked at the wiring diagram?
Do you have a multi meter? What's the battery voltage?
I do not understand what you mean by "Fuse Lights" Fuses don't normally have lights, so I'm wondering exactly what you mean. Can you post a picture of the lights? and tell year of the caravan?
Thank you
