Thanks. I have never used either so unsure if they will cover the white marks which is basically where the veneer had been chipped exposing the chipboard underneath.Could try Topps polish it comes in a variety of shades to match your furniture. Rustins do similar scratch remover for woods
Topps is now Mr Sheen etc etc.Thanks. I have never used either so unsure if they will cover the white marks which is basically where the veneer had been chipped exposing the chipboard underneath.
Beachball, Buckman has already raised it as a query on a new thread. It happened to me very recently and Parksy sorted out the multiple posts.Marks on furniture has come up six times is there a fault
Thanks unfortunately not being a DIY person I am not 100% sure about the coloured wax repair sticks and what I should be buying. Saw these. but not sure if they are correct.Topps is now Mr Sheen etc etc.
I’ve used that them at home and in vans. You need try it on an inconspicuous area first. Don’t expect as new but they do take the impact of the scratch away. There are coloured wax repair sticks too which can lift an indent up again so you don’t see it so visibly. Sometimes with the liquid ones you need successive coats to build up the colour in the substrate.
They could be okay. You don’t really need to be a DIY person, just draw on your experience with a duster 🤣But seriously they are dead easy to use. You work from the closest shade erring towards lighter rather than darker. Try it on the damaged area least noticeable before ones in direct sight.Thanks unfortunately not being a DIY person I am not 100% sure about the coloured wax repair sticks and what I should be buying. Saw these. but not sure if they are correct.
