Hi anyone help.
I have a Fleetwood caravan with a MEC alarm fitted, I am just getting it ready for the new season, had battery off to re-charge. Found that battery past its best so got new battery. Gone to fit it and when connected the alarm goes off, so put code in (as stated in instructions book), but can't stop alarm.
On the control pannel there is 2 lights, 1 green and 1 red, when I connect battery the green light is on. According to the instructions you press * button to activate the control pannel and the red light should be lit to indicate the key pad is active and the green light lit to show the alarm is set ( at this point only the green light is lit), then you enter your 4 digit code, followed by 2 to disarm the system. Then the two lights should go out, but nothing happens ie alarm still going off. Tried several times.
Can anyone help.
Does anyone know if the company MEC Ltd at Mytholmroyd, West Yorshire is still in business because can't contact then on phone number on back of manual.
Many Thanks
Can anyone help.
Many Thanks
