Mercedes E Class saloon
Oct 26, 2007
64
Dose anyone use a E CLASS Mercedes saloon to tow a 1400KG caravan ( car age about 2006 -2008) if so ,have you found the need to inprove the suspension in any way.Your help is of great use Thank you
901
No experience, but why should one need to improve the suspension unless there is something wrong with it in the first place? You can't load the back end of the car any more if you tow than if the boot was loaded to the limit in the solo condition.
40
I tow a 1500kg Burstner with an E220 cdi auto without any problems except getting the noseweight down to 75kg. On this basis you should be fine. The auto box (Tiptronic) is very good and is easy to override manually - very useful for long descents. Fuel consumption depends on how heavy your foot and the prevailing wind. At 50 mph in calm conditions I can get around 27 mpg - it seems to be improving as the engine beds in - only 13,000 miles at the moment.
If you have an auto box and tow a lot, think about getting the transmission fluid changed earlier than the 'book' suggests.
