Micro Switch
Oct 17, 2006
1,489
Apparently the reason our Thetford Bench type toilet pump does not work, we understand their is a micro switch and can get stuck, can anybody tell me where the micro switch is located.
Regards Liz
936
Liz, it is at the base of the flush/blade operating knob.
It is only accessable from the outside, after the cassette has been removed.
Oct 17, 2006
1,489
Hi Damian, Thanks, just a little more help, after removing cassette, what does switch look like, can it be easily found, when found what should I do, is it removable. Sorry to be a pain. Liz
936
Liz,
search for "Thetford-europe" in your browser(dont use the " marks!)
When you get the site click on Customer Services, then User Information, then Repair Instructions, then Built in toilets, then C2-C3-C4
scrol down to the C3 listing, then look for Switch, download the instructions.
Oct 17, 2006
1,489
Thanks Damian for your help it would be nice to get it working again. Hubby changed the pump, it did work for short while, now has stopped, I will download the instructions. I will give it a go, Hubby has now got fed up with it. Regards Liz
